Stable setup with TT S2-3200 and DVBVIEWER ?
os1
Hi
I am trying to setup my HTPC with Technotrend S2-3200 dvb-s/dvb-s2 card with DVBViewer.
My system freezes up a lot. Tried a few different codecs but it still is buggy. I'm considering buying a faster pc/better graphic card.
My hope is that if people have a stable system with S2-3200 and DVBViewer, they would post their setup here.
Please post your hardware, OS, codecs, option settings etc.
It would be nice to have a thread focusing only on stable setups. This should be done for different tv cards I think. It would benefit lazy guys like me :) , and others in this forum.
I would appreciate any feedback ;)
OS1
Beta-Driver 5.0.0.2, Vista (or XP), NVidia-Decoder with MPEG2 (Cyberlink has a small bug in newest version), Cyberlink PowerDVD with H264, AC3-decoder sound via SPDIF, Overlay.
Problems occur mostly with CAM. Above configuration is 100% stable without CAM and without Plugins.
Check your signal strength too, it might be an issue.
Works just fine for me now that I rewired the satellite wall socket.
System: C2D @ 2.2 Ghz, ATi X700 Class, connected to HDTV via HDMI.
Conax CAM with Canal Digital (nordic) subscription card.
Running recent beta with TT 5.x.x drivers.
Cyberlink for MPEG2 and h.264
Edited by Dr. Cain
Pentium4 D 920 2.8 GHz, Asus P5LD2-VM, ATi x1600 Pro, Vista 32, Cyberlink decoder for MPEG2 and H264, TT Driver 5.0.0.2, VMR 9, T-Rex CAM
it works good
AMD x2 5000, Asus M2A-VM HDMI, 2GB DDR2 800, Vista Ultimate 32, Cyberlink 7.3 newest Update, TT Driver Beta 5.0.0.2 using Technisat Sky HD (combatible to TT S2-3200) works fine, Videocard is onboard AMD 690 chipset
Intel Core 2 Duo T7200 @ 2Ghz (Mobile CPU -> low energy consumption) on Gigabyte ATX-Board with i945GM Express Chipset, Nvidia 7950 GT, Cyberlink Decoder 2211a for H.264, MPEG2 and Audio.
Works very good and stable
no hangups or scrambling windows with artefacts with your configuratio ?
Asus M2NPV-VM motherboard. AMD Athlon 64 X2 3800+ 1GB RAM Nvidia 7600GT graphics card
Vista Ultimate 32, Cyberlink 7.3 newest Update, TT Driver 4.4.10.18
I use the above system directly connected to my projector (Panasonic PT-AE700) but also I use it running DVBServer & then running DVBViewer on a client with the following configuration:-
Asus M2NPV-VM motherboard. AMD Athlon 64 X2 4600+ 1GB RAM Onboard Nvidia 6150 graphics
Windows XP Media Center Edition, Cyberlink 7.3 newest Update
I have also used the Nvidia decoders for MPEG2 & CoreAVC for MPEG4
All is perfectly stable & works very well with CI, T.Rex Supermodule & Sky HD or INXTC subscription card.
Edited by nigelbb
core 2 duo 1.86ghz
2gb ram
TT3200 & CI
DVBViewer - latest version and GE for High def decoding on nvidia 8600 GT (run's alot smoother and can record it) Cyberlink V7 decoders using hardware acceleration.
Works like a dream - now to get the cams running nicely..............
  • 1 month later...
Now i have it working with the CAM too on DVBViewer but not with DVBViewer GE though- Trex for premiere HD and it records well too - i couldnn't get version 5 dba driver for TT3200 to work on vista32. so I user the 4.18 version works fine.
DVBViewer GE do not support Encrypted channels.
