Vista 64bit, DVBviewer & Cyberlink Audio Decoder
Huigie
If in DVBViewer I go to view->Filters->Cyberlink Audio Decoder a screen pops up. In XP I could change the "speaker environment" to 6 speaker but this setting does not change in Vista. If I select "6 speakers" it return immediately to "2 speakers" again.
In Creative audio console 5:1 is selected, the same in Vista Sound control panel. I use all the latest versions of software and drivers.
Any idea?
Found 1 thing
XP
Vista
Looks like Vista is loading 2 audio codecs...
If I play a DVD with DVBViewer, the "MPEG audio decoder" dissapears, the Cyberlink Decoder then lets itself change the setting to 6 speakers properly and it works like it should. If I then change back to TV the "MPEG audio decoder" takes over again. Very frustrating...
Edited by Huigie
