Missing subtitle in H.264 recording
nicke_lilltroll
Hi. I´ve been struggeling with subtitles and hd recordings and wonder if this might be a bug.
I´ve come this far:
All the relative options in recording settings are enabled as well as file format is set to .ts.
When playing a regular mpeg-2 coded recording the subtiltle selection is active if the
"Use DVBSource for mpg-files" in DirectX settings is enabled.
So far so good, but when I try to play a H.264 coded recording I get subtitles alright but no picture.
If I disable the DVBSource i get the picture back in the H.264 recording, but no selection of subtitles.
I have tried both VMR7 and VMR9 also, but no success.
How can I make this work??
DVB subtitles in a H.264 recording (It is an overlay render issue, isn´t it???????)
Edited by nicke_lilltroll
