Free LNB Tool
If you don't know what it's good for: It had been requested here.
And may be it's good to switch off the SS2 anyway, while it is idle, so it doesn't work as a heating all the time and lives a bit longer... but I don't know if this switching off keeps it cool. Somebody with a real hot SS2 should test it.
Griga
Guest hackbart
well i suppose it wont be cooler than before :lol: Nevertheless i also added the feature into DVBViewer. If you disable the "remember last data channel" the lnb will automatically be reset.
Christian B)
