Rittberg Posted June 25, 2007 Posted June 25, 2007 (edited) Hi, Yesterday I reinstalled DVBViewer (not before I copy the old installation in to another folder). The channel list was exported from the old installation and than imported to the new installation. With the "Favorites" I faced a problem, when I go to the old installation I was able to save it But I don't find where the file is saved so I was forced to create the "Favorites" once again. BTW - I copy the favorits.XML from the old to the new installation but no-go. Thanks for your Idea. Edited June 25, 2007 by Rittberg Quote
Oliver Posted June 25, 2007 Posted June 25, 2007 Well, that depends on the installation mode (compatible, ...). With "compatible" it's in the DVBViewer folder, otherwise in "documents & settings" (all users or your current account). Quote
Rittberg Posted June 25, 2007 Author Posted June 25, 2007 I looked after the file but I didn't find it, How should it look like ? Quote
hdv Posted June 25, 2007 Posted June 25, 2007 Hello, you find your current settings under DVBViewer Pro -> About -> Info -> Versionsinfo -> (the blue Link). Quote
