Problem ? H264/AVC with FFDShow under Vista 64
LePouSAT
Hi all !
DVBViewer latest version crashes immediately when I set FFDShow as my H264/AVC codec and when I switch to an HD TV Channel (DVB-S2).
But it works perfectly for DVB-S channels ...
I tried to set the H264/AVC codec as "System Default" but I am missing a deinterlacing setting ... CoreAVC gives me a scrambled and/or green picture ...
Anyone has a solution ?
I enclosed my "support.zip" file ...
Thanks in advance for your replies ...
LePouSAT
solution: Don't use ffdshow for H.264 :P
Try the cyberlink h.264 decoder which comes with power DVD.
I tried, it works but on some channels I get an interlaced video stream and no way to add a deinterlace setting ...
Any way to deinterlace the video stream when using the Cyberlink codec ?
LePouSAT
click on view->filter and then the cyberlink decoder. This will pop up the options for the cyberlink decoder. You should try force bob or force weave for deinterlacing.
