kaisersose Posted June 25, 2007 Posted June 25, 2007 (edited) My PC is a dell e520 with an e6300 core2duo @1.86ghz , skystar HD, 8500gt (158.45 drivers) and the cyberlink h264 codec. Im using DVBViewer ge and EVR. BBC HD is about 15% cpu usage but all the german fta H264 channels are about 25%. Is that cpu usage normal for those channels with a spec like mine? edit: and just after noticing, cpu usage is the same for BBC HD when use only 1 cpu is ticked and same for the german channels Is this right? Also the sound skips on some H264 channels even though video is fine, same for all audio codecs Edited June 25, 2007 by kaisersose Quote
