DVBViewer crash
Bigsound
I hope someone can help me with this problem I have.
When I changing channel DVBViewer crashes. "DVBViewer.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
This is realy irritating and hope to fix it soon.
Could it be something with EPG? (That I transfer EPG at the same time)???
Please help me someone
I have two Technotrend 3200 DVB-S with driver version budget2_4.4.10.18
P5LD2 Deluxe motherbord
graphiccard ATI x1600 with driver version 8.351.0.0
I use ffdshow,powerdvd7 and nvidia codecs.
something more you want to know?
I dont know hove to explain it easiler. The program just stops after one ore two channel changes??
Sorry. I read to fast. I suppose I should send this support.zip file I get now in this message... Well,here it is...
2007-07-01 18:53:09 EAccessViolation raised by instance frmMain of class TfrmMain at 056E5A7B:Zugriffsverletzung bei Adresse 056E5A7B in Modul 'PushSource.ax'. Lesen von Adresse 0000002A
2007-07-01 18:53:09 EAccessViolation raised by instance frmMain of class TfrmMain at 0041455C:Zugriffsverletzung bei Adresse 0041455C in Modul 'DVBViewer.exe'. Lesen von Adresse 0000009C
2007-07-01 18:53:11 EAccessViolation raised by instance tmrColorkey of class TTimer at 0041455C:Zugriffsverletzung bei Adresse 0041455C in Modul 'DVBViewer.exe'. Lesen von Adresse 0000009C
2007-07-02 20:26:43 EInvalidPointer raised by instance frmInputOptions of class TfrmInputOptions at 00402BEC:Ungültige Zeigeroperation
2007-07-03 20:37:19 EAccessViolation raised by instance of class TApplication at 00404B24:Zugriffsverletzung bei Adresse 00404B24 in Modul 'DVBViewer.exe'. Lesen von Adresse FFFFFFDC
2007-07-03 20:37:19 EAccessViolation raised by instance frmMain of class TfrmMain at 0041455C:Zugriffsverletzung bei Adresse 0041455C in Modul 'DVBViewer.exe'. Lesen von Adresse 0000009C
but as to why those errors occur. I'm sure a dev will look into it, but it might take some time. Did the error occurs from the beginning (e.g. when you started using DVBViewer with your configuration) or did something change along the way which started to cause the errors?
In the meantime, you could try:
* change the video-codec
* change the audio-codec
* deactivate plug-ins (you talk about "Could it be something with EPG? (That I transfer EPG at the same time)???", do you mean EPGImport or something?)
* deactivate one DVB-card
* update DVBSource
* make sure Windows is up to date, as well as any drivers and codecs
* check the Windows logs to see if something else is reporting errors as well
Edited by Klaus_1250
Now I have tried on a new installed computer and new installed DVBViewer. But this shit is still not working. Got dam it! Please someone help me with this irritating problem.
/Mikael
This is the windows log:
Faulting application DVBViewer.exe, version 3.6.1.20, faulting module ntdll.dll, version 5.1.2600.2180, fault address 0x00018fea.
Edited by Bigsound
My post got removed due to the server move. But, BigSound, can you post some more information on your PC (hardware and all software)? Have you checked my list with possible suggestions?
Last, you talk about nvidia codecs but have an ATI card?
  • 1 month later...
I know, prolly to late but:
You have a ram error, check it first with memtest86.
if memtest veryfies this, change ram dimm.
