gzez Posted July 5, 2007 Posted July 5, 2007 Hello Can someone explain how I install and configure this plugin. I have extract zipfile into DVBViewer folder, but nothing happens when I execute HTTPServer.exe. I dont know what to do after that. Readme file doesnt give much info, so PLEASE can someone tell how to get this plugin working, or write a better readme,,, BIG THANK YOU for you who help me and probably many more. over and out from Sweden =] Sincerely Jocke Quote
Tjod Posted July 19, 2007 Posted July 19, 2007 Usage:------ Start the server. Check the used Port and Interface. ATTENTION: You may have to adjust the port if you have another webserver running on the default port!! Interface is the Network-adress the webserver is listening for requests. 127.0.0.1 only connects from the local computer are allowed 0.0.0.0 the webserver will listen on all available network cards. [Your-IP] The Webserver will listen on the specified network card. Attention: Don't use the IP of your DVB-Card (Only technisat *Star users affected) this won't work. The webserver does not interact with the DVB device, only with the DVBViewer. If you have set up all, activate the webserver. Now you can open the Internetbrowser of your choise and point it to the IP of the computer running the webserver. Example: Your webserver runs on the computer with the IP 192.168.0.10 and you set Port 8080 then http://192.168.0.10:8080 would be the URL to open the page. If you set Port 80 you can drop the Port and only write http://192.168.0.10 . If all works well you get the login page. The default passwort and User: User: admin Password : admin You can and should change this with the integrated configurationpage in the webbrowser. If the DVBViewer is not running you see a page, where you can start the DVBViewer. Just press the button and the DVBViewer starts and the default page is shown automatically. Just Activate the HTTPServer and open in your Browser http://127.0.0.1/. Quote
gzez Posted July 23, 2007 Author Posted July 23, 2007 (edited) Just Activate the HTTPServer and open in your Browser http://127.0.0.1/. Thanks! Only thing is when i recieve stream from http-server, picture is striped in horizon , so its very hard to watch. Is there any solution for this? Edited July 26, 2007 by gzez Quote
