H.264 problem
moyo
Hi, I have installed H.264 CoreAVC decoder (file CoreAVCDecoder.ax v1.3.0.0) and I, of course, I have selected to use this decoder as H.264 decoder (in Options -> DirectX). The sound is OK but the picture isn't. All I can see are coloured brands (see attached file ... picture snapshot). This brands are not "static" but they are changing depending on broadcasted program. Has anybody any idea where could be the problem ? Thank you.
PS: I had to reduce attached image size because JPEG file was too big to be able upload it. Its original size was 1440x1088 pixels.
Edited by moyo
CoreAVC doesn't handle interlaced h264 properly. It used to sometime in the past, but they broke it in an update. Being CoreAVC, they don't respond to emails so nobody knows if they intend to fix it.
... and is there any decoder supporting interlaced h264 properly?
well, you were right! I've tried to use v1.2.0.0 instead of v.1.3.0.0 and it works! Thanx.
Cyberlink's does, at least with my Vista/8500GT. In software mode you have to force bob in decoder properties, or it weaves everything.
Mainconcept's software one seems OK too.
Tick Settings -> Options -> DirectX -> Video Format Detection. The CoreAVC must be informed about the resolution when connecting to the DVBViewer Filter, since it is not able to detect it by itself. Without pre-format detection the DVBViewer Filter reports 1920 x 1088 as default.
