xzone Posted July 12, 2007 Posted July 12, 2007 (edited) pls help me eutel w3 hd5 hd2/5 good no problem but luxehd restart my computer amd 4600 x2 7900gt 1gb 800mhz ram dfi nf590 lanparty powerdvd 7 help me Edited July 12, 2007 by xzone Quote
Derrick Posted July 12, 2007 Posted July 12, 2007 (edited) I can confirm this problem. DVBViewer crashes with BSOD. AltDVB is playing but the picture is very jerky with lots of blocking artefacts. Dunno why DVBViewer is causing trouble. Apparently it's related to the nvidia driver but why not the same with altdvb and same direct show graph ??? maybe it's caused by an unusual resolution format? Video-PID = 101 profile_idc = 77 -----> main profile constraint_set0_flag = 0 constraint_set1_flag = 1 constraint_set2_flag = 0 constraint_set3_flag = 0 level_idc = 40 -----> level 4.0 seq_parameter_set_id = 0 log2_max_frame_num_minus4 = 0 pic_order_cnt_type = 0 log2_max_pic_order_cnt_lsb_minus4 = 2 num_ref_frames = 2 gaps_in_frame_num_value_allowed_flag = 0 pic_width_in_mbs_minus1 = 79 -----> HRes = 1280 pic_height_in_map_units_minus1 = 33 -----> VRes = 1088 frame_mbs_only_flag = 0 -----> interlaced mb_adaptive_frame_field_flag = 1 direct_8x8_interference_flag = 1 frame_cropping_flag = 1 frame_crop_left_offset = 0 frame_crop_right_offset = 0 frame_crop_top_offset = 0 frame_crop_bottom_offset = -1 vui_parameters_present_flag = 1 aspect_ratio_info_present_flag = 1 aspect_ratio_idc = 255 sar_width = 3 sar_height = 2 -----> aspect ratio 16:9 overscan_info_present_flag = 0 video_signal_type_present_flag = 1 video_format = 5 ------> unspecified video_full_range_flag = 1 colour_description_present_flag = 1 colour_primaries = 2 transfer_characteristics = 2 matrix_coefficients = 2 chroma_loc_info_present_flag = 0 timing_info_present_flag = 1 num_units_in_tick = 384 time_scale = 16777217 fixed_frame_rate_flag = 1 nal_hrd_parameters_Present_flag = 0 vcl_hrd_parameters_Present_flag = 0 pic_struct_present_flag = 0 bitstream_restriction_flag = 0 here are the last entries of the debug.log before the BSOD: 12.07.2007 14:20:48 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo RGB 1024X-1024, 32 bits12.07.2007 14:20:48 CheckMediaType Width: 1024 - Height: -1024 12.07.2007 14:20:48 QueryAccept Result: Unzulässige Funktion 12.07.2007 14:20:48 Used Filter 0: VMR 7 Renderer 12.07.2007 14:20:48 Used Filter 1: Default DirectSound Device 12.07.2007 14:20:48 Used Filter 2: Color Space Converter 12.07.2007 14:20:48 Used Filter 3: AC3Filter 12.07.2007 14:20:48 Used Filter 4: CyberLink H.264/AVC Decoder (PDVD7) 12.07.2007 14:20:48 Used Filter 5: DVBV OSD-Source 12.07.2007 14:20:48 Used Filter 6: DVB Source 12.07.2007 14:21:00 Settuner Start 12.07.2007 14:21:00 Allocate Hardware Pinnacle PCTV 4XXe Tuner 12.07.2007 14:21:00 Settuner Found usable hardware 12.07.2007 14:21:00 Release Hardware Pinnacle PCTV 4XXe Tuner 12.07.2007 14:21:00 Settuner Hardware.SetTuner 12.07.2007 14:21:00 TDVBHardware.SetTuner PMT: 32 - SID: 1 12.07.2007 14:21:02 Settuner End 12.07.2007 14:21:02 Plugin PIDDelete 721 12.07.2007 14:21:02 Plugin PIDAdd 1 12.07.2007 14:21:02 Plugin PIDDelete 1 12.07.2007 14:21:02 Plugin PIDAdd 255 12.07.2007 14:21:02 Plugin PIDAdd 257 12.07.2007 14:21:02 Used Filter 0: VMR 7 Renderer 12.07.2007 14:21:02 Used Filter 1: Default DirectSound Device 12.07.2007 14:21:02 Used Filter 2: Color Space Converter 12.07.2007 14:21:02 Used Filter 3: AC3Filter 12.07.2007 14:21:02 Used Filter 4: CyberLink H.264/AVC Decoder (PDVD7) 12.07.2007 14:21:02 Used Filter 5: DVBV OSD-Source 12.07.2007 14:21:02 Used Filter 6: DVB Source strange enough altdvb seems unimpressed Edited July 12, 2007 by Derrick Quote
Rittberg Posted July 13, 2007 Posted July 13, 2007 I have solved this problem by "uncheck" the DXVA in the PDVD video settings. Quote
Derrick Posted July 13, 2007 Posted July 13, 2007 ..that doesn't answer the question why the dvbviewer_pro_beta crashes and not other programs. Quote
Griga Posted July 13, 2007 Posted July 13, 2007 Used Filter 0: VMR 7 Renderer May be the OSD source that is connected to the renderer finally tips the balance. What about overlay? Quote
Derrick Posted July 13, 2007 Posted July 13, 2007 Doesn't matter, all renderers will crash the DVBViewer. It didn't happen with an older version.. Quote
xzone Posted July 14, 2007 Author Posted July 14, 2007 my card skystarhd (powerdvd7) codec restart computer (all dvb program) restart luxehd tv but main concept codec good no problem interesting (=: Quote
Rittberg Posted July 14, 2007 Posted July 14, 2007 but main concept codec good no problem interesting (=: Due to the fact that main concept codec doesn't use the DXVA. Quote
ricabullah Posted July 16, 2007 Posted July 16, 2007 (edited) pls help me eutel w3 hd5 hd2/5 good no problem but luxehd restart my computer that doesn't answer the question why the dvbviewer_pro_beta crashes and not other programs. Hi derrick! As far as i understand he didn't say "beta" I never met any problem nor with LuxeTV, neither with the others. First, forget OSD, just try to choose renderer as "unchanged". Second, forget using HA(PVHD) with a 7900gt(never works), Third, change your GPU with an 8500 or 8600 if you want to activate HA and install 165.01 beta than beta(!) FW. (for XP) (thanks CiNcH) Last trick, while watching with "unchanged" renderer, start recording. (thanks griga!) After you can prepare freely a custom-made graph without an OSD filter with WMR9 and watch with best quality. Overlay mixer? I never prefer with its worst quality. best! Edited July 16, 2007 by ricabullah Quote
