Breffni Posted March 19, 2003 Posted March 19, 2003 Christian, Knowing that 4:2:2 is not an encryption system, I wonder if you could help me with the settings to be made in order to view this type of signal using DVBViewer. I read somewhere that this could be done making some rendering adjustments (whatever that means). Thanks in advance for the help. Regards Breffni Quote
Guest Oliver Posted March 19, 2003 Posted March 19, 2003 Hello! Well, it's a method of compression. The best is 4:4:4. You have to have installed the correct codec to watch corresponding videofiles with DVBViewer. But every MP2- and DivX-decoder known to me is capable of that. Bye, Oliver Quote
Breffni Posted March 19, 2003 Author Posted March 19, 2003 Oliver, 4:2:2 is not a video codec - Divx type of thing. It is a DVB transmission system, a kind of softcrypt used for feeds, which be received by dedicated receivers OR by changing certain parameters (rendering parameters) in software, such as DVBViewer. Can anyone esle help! Thanks all the same Regards Breffni Quote
Guest Oliver Posted March 19, 2003 Posted March 19, 2003 Obviously you failed to understand. Of course it's not a video-codec. It's a mean of compressing video-data. Usually there are 4:4:4, 4:4:2, 4:2:2, 4:2:1 and 4:2:0. Here is some additional information for you: MPEG-2 video extends the sampling-choices to three t; the old 4:2:0, and the new ones are 4:2:2, and 4:4:4. DVD-video, which is a contrained-parameter MPEG2 is restricted to 4:2:0, so that's all that counts. Incidentally 4:2:2 is functionally equivalent (though not exactly the same, implementation wise) to the YUV-packed formats YUY2, UYVY. Both are 16bpp, and both subsample the CbCr (U/V) data 1/2 in horizontal (so a 720x480 4:2:2 frame = 720x480 Y, 360x480 U, 360x480 V) Bye, Oliver Quote
Guest hackbart Posted March 19, 2003 Posted March 19, 2003 Hmm, 4:2:2 is a mpeg2 norm which only contains each 2nd C-Point of a signal. Normally used for cable broadcasters.. I really do not have any influence in the data packages coming from the satellite. The mpeg data is decoded via the decoder, which should handle these things. Christian Quote
Guest Oliver Posted March 22, 2003 Posted March 22, 2003 Hello! I've found some detailed descriptions of the different formats. Link 3 has a real good draft of them on page 15. Link 1 Link 2 Link 3 Bye, Oliver Quote
bmedia Posted July 5, 2003 Posted July 5, 2003 How can I watch EBU feeds (mpeg 4.2.2) with DVBViewer 199R6?? Sorry for bad English, but I hope you can help me. P III 664 Mhz 256 MB Skystar 2 card Greetings Bart Quote
Guest Oliver Posted July 5, 2003 Posted July 5, 2003 What exactly is your problem with those? Usually 4:2:2 transmissions run just fine. Bye, Oliver Quote
bmedia Posted July 5, 2003 Posted July 5, 2003 Now at 1:00h I can see a signal (45 procent) but no picture :-( With progdvb I can watch 4.2.2 but not perfectly. Greetings Bart Quote
Guest Oliver Posted July 5, 2003 Posted July 5, 2003 Could you tell us which channels are concerned? Bye, Oliver Quote
sirius_4 Posted July 21, 2003 Posted July 21, 2003 @klausing EBU is an union off all european state tv-stations for example RAI, TVE, SRG, ORF, TF1 also known as EUROVISION !!! Feeds can you recieve on the eutelsat w3 at 7°east/ all feeds are encoded in mpeg 4:2:2. Quote
NEWS24x7 Posted October 12, 2003 Posted October 12, 2003 I'm suprised that no one has written a firmware replacement for one or more of the common STB's to view 4.2.2. Not being that smart, I'm definatly not the person. Quote
Guest hackbart Posted October 12, 2003 Posted October 12, 2003 Prog uses the Elecard Decoder Filter. To get 4:2:2 streams run properly in the DVBViewer just change the Decoder to Intervideo, Cyberlink or Elecard. Christian Quote
Derrick Posted October 12, 2003 Posted October 12, 2003 Prog uses the Elecard Decoder Filter. To get 4:2:2 streams run properly in the DVBViewer just change the Decoder to Intervideo, Cyberlink or Elecard. Christian Neither windvd (Intervideo) nor powerdvd (Cyberlink) is able to decode 4:2:2.. you have to switch to elecard. Quote
boborg Posted October 22, 2003 Posted October 22, 2003 elecard is also the only with working 4:2:2 for me. Is the signal strength of more importance with 4:2:2? Yesterday on a 4:2:2 feed I had 30% strength but still squares freezing from time to time. Quote
Derrick Posted October 22, 2003 Posted October 22, 2003 Is the signal strength of more importance with 4:2:2? Yesterday on a 4:2:2 feed I had 30% strength but still squares freezing from time to time. ..no, the signal strength (signal quality is the better term ) is not related to the different formats though it could be that elecard's codec has a lesser concealment algo than other decoders. If the error rate (can be monitored with the technisat tool) stays at zero, it should be ok. Why the signal strength sometimes changes when some options are changed, imho nobody really knows. The transmission parameters are monitored upstream in the frontend. Quote
boborg Posted October 22, 2003 Posted October 22, 2003 OK thanks. Don't think I actually had anything but 0 in the error rate. I think I checked it as I was unsure if the freezing was a signal or filter issue. Will have to wait for another 4:2:2 feed to check it again. My P4 2,40 should be able to handle it.. Quote
