PhilW Posted July 15, 2007 Posted July 15, 2007 What does one do if the relevant satellite does not exist in the pick list during set up via wizard. Is there any way of editing a database for this? Does it really matter? Satellite commisioned 2 months ago, and is one of the most important to New Zealand and Australia. Quote
Moses Posted July 15, 2007 Posted July 15, 2007 ignore the wizard, skip the scan. Then try to get a transponder *.ini for the SAT. You could try google or lyng sat or so... copy that one to your DVBViewer\Transponders Folder (and maybe remove the other *.ini files you don't need) and the sat should show up in the list, when you try to start a manual channel scan in DVBViewer. Quote
