lordbaco Posted July 16, 2007 Posted July 16, 2007 (edited) DVBViewer is a great software but it is useless because I am unable to use the CineView CI module of KNC One S2 Plus. So what can I do in order to use it ? N.B. my KNC One S2 is working for unscramble tv channel like Astra HD1, Euronews, etc. and the CI Menu is not available in both stable or beta version of DVBViewer. My configuration : Intel Core 2 Duo 2.4GHz, 2GB RAM, Vista Home Prenium 32Bits KNC One S2 Plus CineView CI CAM AstonCrypt DVB-CI (Mediacrypt) Canal+ CanalSatellite (Original and working on Humax and on GlobalTV with WDM) BDA 1.7.4.2 Beta 32 Bits on Vista Microsoft Visual C++ runtime 2005 (x86) kncbdactrl.dll from GlobalTV 2.1.1.4 Build 0.5.0.4 Betaversion 32 Bits DVBViewer 3.6.4.20 beta (also 3.6.1.20) See also (unable to understand german, sorry) http://www.DVBViewer.info/forum/index.php?...2&hl=kncone http://www.DVBViewer.info/forum/index.php?showtopic=17711 http://www.kncone.de/d/download/digital.htm If you will never support it please tell me if you will support the CI of Technotrend TT 3650 S2 CI. What hardware to buy for DVB-S2 with CI working for CSAT France. http://www.technotrend.de/2715/TT-connect__S2-3650_CI.html http://www.dvbshop.net/popup_image.php?pID=264&imgID=1 I bougth your software because KNC One S2 Plus is listed on your feactures list but you don't tell the truth about CI supported or not http://www.DVBViewer.com/en/index.php?page=features Edited July 16, 2007 by lordbaco Quote
Griga Posted July 16, 2007 Posted July 16, 2007 What you need is this (as reported in the German section of this board, source): - DVBViewer Pro Beta - the latest KNC BDA driver - the file KNCBDACTRL.dll (see here) in the DVBViewer directory - a GlobeTV installation, in order to get some other DLLs (MS runtime libraries needed by KNCBDACTRL.dll, see here). Quote
Derrick Posted July 16, 2007 Posted July 16, 2007 What you need is this (as reported in the German section of this board, source): Following this link you'll find a description how to get a CI partially working. But @lordbaco asked for the CI menu: the CI Menu is not available in both stable or beta version of DVBViewer. ..in the proposed workaround the menu is not working: Was funktioniert nicht ? - Das CI-Menü kann in der 3.6.4.2 BETA geöffnet werden, jedoch keine Anzeige (you can open the menu but it remains empty) Quote
Griga Posted July 16, 2007 Posted July 16, 2007 But @lordbaco asked for the CI menu You are right. I shouldn't try to do support while I'm involved in heavy coding. Quote
