Stream to xbox mediacenter
gzez
If you have XBMC on your old mod xbox and want to stream DVBViewer-channels to your xbox, there is a great script for XBMC that calls xmtv ( http://www.xbmcscripts.com/index.php?optio...4&Itemid=36 )
"" Here a server for PC and a python script for XBMC to watch tv with help of DVBViewer (www.DVBViewer.com). Features: TV, Radio + EPG ...more maybe later PC: For the server you need Microsoft .NET Framework 2.0. After the start it will be located in systemtray. Type in a portnumber of your choice (e.g 4711) and press start. The DVBViewer should be running. Also the NetStream Plugin in DVBViewer has to be configured and activated. XBOX: Copy the xmtv folder to the scripts folder on XBMC. On first start type in the IP-Address of the server. Then the portnumber you have choosen. After that the NetStream Port. Happy watching este""
I have tryed it for some weeks now, and it works good, only negative is that subtitles is not supported.
