subdvbv Posted July 17, 2007 Posted July 17, 2007 Hi Everyone, can anyone give me the definitive answer to the following questions 1. Technotrend s2-3200: a. Does Diseqc1.2 under DVBViewer work with this card. b. if so what version of DVBViewer and plugins do I need c. Does the CI interface that comes with this card work with DVBViewer d. if so what CAM/Card would I need to decode Premiere HD 2. Twinhan DVB-S2 (= DIGITAL RISE = AZUREWAVE AD-SP 400) a. Does Diseqc1.2 under DVBViewer work with this card. b. if so what version of DVBViewer and plugins do I need c. Does the CI interface that comes with this card work with DVBViewer d. if so what CAM/Card would I need to decode Premiere HD 3. Technotrend s2-3600 usb a. Does Diseqc1.2 under DVBViewer work with this card. b. if so what version of DVBViewer and plugins do I need c. Does the CI interface that comes with this card work with DVBViewer d. if so what CAM/Card would I need to decode Premiere HD 4. Hauppague HVR-4000 a. Does Diseqc1.2 under DVBViewer work with this card. b. if so what version of DVBViewer and plugins do I need c. Does the CI interface that comes with this card work with DVBViewer d. if so what CAM/Card would I need to decode Premiere HD Thanks to everyone for their time Quote
Moses Posted July 17, 2007 Posted July 17, 2007 1. c) Works very good. d) For Premiere HD on Astra 19.2° East, I'd recommend an alphacrypt light. a & b: I don't need it myself and posts in this forum from hackbart say, that DiseqC 1.2 would work, griga said, it doesn't work... so I'm not sure.. Quote
morph Posted July 17, 2007 Posted July 17, 2007 4. Hauppague HVR-4000a. Does Diseqc1.2 under DVBViewer work with this card. b. if so what version of DVBViewer and plugins do I need c. Does the CI interface that comes with this card work with DVBViewer d. if so what CAM/Card would I need to decode Premiere HD a) YES actual beta c) there is no CI bundled with this card d) look at c) many of the cards you mentioned havn't got any CI option... Quote
Lars_MQ Posted July 17, 2007 Posted July 17, 2007 DiseqC 1.2 does work. Griga does only know the BDA interface, we use a extended interface (also needed for CI). 1 + 2 will work 3+ 4 have no CI so now CAM so no Premiere HD. Quote
Derrick Posted July 17, 2007 Posted July 17, 2007 There is hardly any support for diseqc 1.2. And a mandatory fail safe function is still not implemented Quote
