EPG in CZ
xmonika
After one week of using DVBViewer and countless of tries, I'm still not able to use EPG in appropriate form. There are in one channel program informations from different channel. Is there any settings necessary to be set?
You can't solve the problem with the current release. It's by design. In the current Beta the problem should be solved.
Depends on which channels. HBO transmits different characters than other channels.
Thanx for quick reply. I will became beta tester and will report the results back.
