Pip diden't work for 2 H264 SD channel
Etienne
Since my scanning problems are solved (diseqc + DVBViewer version) , i have discover perhaps a bug.
Always same TP (2 channels only in FTA H264 SD )
Atlantic Bird 3 (5.0W) - 11609.00 V - Txp:KB4 - Faisceau:Super DVB-S (QPSK) - 6944 1/2 - NID:144 - TID:100
PIP dident work
On ( 6 channels Mpeg2 SD ):
Atlantic Bird 3 (5.0W) - 11590.00 V - Txp:KB4 - Faisceau:Super DVB-S (QPSK) - 20000 2/3 - NID:8442 - TID:1
PIP works .
Can anybody confirm ?
Etienne
Edited by Etienne
No bug. It's not intended to work. Or can you enter a H.264 decoder for the preview? ;)
Perhaps I diden't understand how PIP works....
For Mpeg2 + Mpeg2 channels -> Cyberlink mpeg2 codec -> works
For H264 + H264 channels -> Cyberlink H264 codec -> dident work
Haven't try Mpeg2 + H264 channel!
there are special decoder settings for pip in DVBViewer...
