PCTV 330e remote
xmonika
This configuration of profiles.ini works for mini remote delivered with Pinnacle PCTV 330e
; Pinaccle PCTV Remote for DVBViewer
;key mapping mini rc5
;mute=60
;pinnacle=1006
;on/off=047
;vol+=27
;vol-=15
;CH+=23
;CH-=28
;1=49
;2=50
;3=51
;4=52
;5=53
;6=54
;7=55
;8=56
;9=57
;0=58
;minimize=45
;T=41
;rew=14, press=78
;play=13
;fwd=007, press=71
;rec=39
;stop=11
;?=29
[default]
hwid=24
rc_filter=all
; protocol={nec|pcle_rc5|pcle_rc6|pcle_rcm}
; keymap={pcle_rcm|t003_rc5|pcle_rc6|mini_rc5|pcle_rc5}
protocol=pcle_rc6
keymap=mini_rc5
rc_id1=0
rc_id2=0
key47=EXEC C:\Program Files\DVBViewer\DVBViewer.exe
[DVBViewer]
key28=KEYBOARD PGDN+^PGDN
key23=KEYBOARD PGUP+^PGUP
key15=KEYBOARD LEFT+^LEFT
key27=KEYBOARD RIGHT+^RIGHT
key49=KEYBOARD NUM1+^NUM1
key50=KEYBOARD NUM2+^NUM2
key51=KEYBOARD NUM3+^NUM3
key52=KEYBOARD NUM4+^NUM4
key53=KEYBOARD NUM5+^NUM5
key54=KEYBOARD NUM6+^NUM6
key55=KEYBOARD NUM7+^NUM7
key56=KEYBOARD NUM8+^NUM8
key57=KEYBOARD NUM9+^NUM9
key58=KEYBOARD NUM0+^NUM0
key29=KEYBOARD ENTER+^ENTER
key45=KEYBOARD ALT+F+^ALT+^F
key39=KEYBOARD c+^c
key11=KEYBOARD S+^S
key13=KEYBOARD SPACE+^SPACE
key14=KEYBOARD R+^R
key7=KEYBOARD F+^F
key41=KEYBOARD F8+^F8
key60=KEYBOARD M+^M
key47=KEYBOARD ALT+F4+^ALT+^F4
key1006=KEYBOARD ESC+^ESC
The file included can be used to track transmitted codes from any of the Pinnacles remote. Maybe useful for somebody trying to get his remote working. Just put the sequence into default section of your profiles.ini file, open blank file and let the remote write the codes...
profiles_keymap.ini
Edited by xmonika
  • 3 years later...
Here are setting for PCTV 290e mini remote
[default]
; start PMC with Remote Type A
;key47=EXEC C:\Program Files\DVBViewer\DVBViewer.exe| /10ft
; start PMC with Remote Type B
key1006=EXEC C:\Program Files\DVBViewer\DVBViewer.exe| /10ft
; Autorun
;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
autorunkey=PMCRemote
; hardware ID: -1 = autodetect
HWID=-1
port=1
;protocol=pcle_rc5
;keymap=mini_rc5
rc_filter=all
rc_id1=0
rc_id2=0
[DVBViewer]
; Sound Up
key23=KEYBOARD UP+^UP
;Sound Down
key28=KEYBOARD DOWN+^DOWN
;Channel up
;Channel Down
key49=KEYBOARD 1+^1
key50=KEYBOARD 2+^2
key51=KEYBOARD 3+^3
key52=KEYBOARD 4+^4
key53=KEYBOARD 5+^5
key54=KEYBOARD 6+^6
key55=KEYBOARD 7+^7
key56=KEYBOARD 8+^8
key57=KEYBOARD 9+^9
key58=KEYBOARD 0+^0
;ok
key26=KEYBOARD ENTER+^ENTER
;rec
key14=KEYBOARD SHIFT+LEFT+^SHIFT+^LEFT
; FastRewind
key39=KEYBOARD r+^r
; FastForward
key7=KEYBOARD SHIFT+RIGHT+^SHIFT+^RIGHT
;Stop
key11=KEYBOARD <+^<
; Play
key13=KEYBOARD p+^p
;Mute
key60=KEYBOARD m+^m
;Full screen
key45=KEYBOARD f+^f
;text tv
key41=KEYBOARD t
; ? button
key43=KEYBOARD ESC+^ESC
All of the buttons will work exept rev&fast forward. I added a shortcut for them in input sources i DVBViewer.
