BDA+SS2?
pkcahier
Hello all,
I have DVBViewer in latest version and am running it on my 2k3 server.
Since the normal network PCI driver do not work on 2k3 I installed the 4.4.1 BDA drivers, which installed and loaded.
However I'm at loss now at what I am upposed to do to get it loading in DVBViewer(Ideally I'd want to stream from that).
(Using the pci drivers was far more easier, but the card was overheating in my normal XP computer with no room, plus I wanted to move it to streaming with my main server)
Any help/pointers will be very appreciated,
Best Regards,
Paul-Kenji Cahier
After checking a bit, I found out that the 2k3 bda driver would cause a reboot, and after doing some modifications, it properly installed it, and everything seems to load now, sorry for that useless question then:)
