Stream errors, how to deal with them?
pkcahier
Hello all,
I have been using the network streaming module, which works fine. Sadly sometimes my reception isnt perfect and some packets come in corrupted/incomplete.
What I have noticed is that the reception resumes after a few s, at the same point where it left. And after this happends a few times, my guess is that the buffer for it gets all filled, and it enters a mode where everything becomes permanently jerky(sound is fine, just video is displaying frames not smoothly).
I have had this behaviour with every single combination of video decoders/audio decoders/video renderers, so I am fairly sure it is at the dvbsource level.(Plus the problem happened both when I had the card directly plugged in, and now using the server/client architecture remotely).
Is there not a way to do some sort of frame dropping so that when something cuts it doesnt display until it's able to catch up and/or it catches up?
That way it wouldnt fill in progressively or so.
Best Regards,
Paul Cahier
You can process a recorded file with either ProjectX or VideoRedo to fix errors inherent in any broadcast.
I am not sure if you can fix a live broadcast "on the fly."
