disable TVwindow on radiostation
Klausing
It would be nice if the videopart of the main window would be automaticaly disabled if i hear radio. Maybe the "video window" would splitted from the "control window" like WinDVD. So the "video window" would only be open if we need it for tv.
See screenshot below.
Steffen
Guest DAvenger
Something like the picture above should be really simple to do ... Windows Media Player 6.4 does it the very same way B)
Guest hackbart
sure, this won't be such a problem, but how about the osd? In my case i use the remote control quite often, also like playing with the onscreen display..
Christian
PS: I think about such an function.. maybe someone has a good idea how to solve.
Guest Michael
me would prefer to make the video window complete independent line in radlight...... and when it is needed ... like for osd... it is opened...
Guest Oliver
That's easy: Make it optional, so that you can choose under settings how it shall be handled. -_-
Bye, Oliver
Guest hackbart
yet more functions ;) okay, i add some checkbox in the menu...
@Micha: I already thought about an "radlight" plugin, which "emulates" RadLight - but to be honest i droped the idea because i love RadLight too much, to write such a thing -_-
Christian
Guest DAvenger
I love the way DVBViewer looks, especially its compact design. So this would look kinda weird (w00t)
Skins* should help to satisfy everone -_-
(*) Free your mind and remember that there is no DVBViewer.exe :bye:
I've just tried a pre-release - he did it (checkbox in the options), and it works. Looks exactly like Klausing's picture.
If I switch over from one radio station to another, however, the DVBViewer seems to be unsure what to do: The video display field opens for a short moment ;) and then closes again -_-
Griga
Yes, there is only one little, small bug, but it looks very good. Christian is a realy fast coder!
