8psk ?
chl
Hi
Its it possible to tune in this channels....i dont have any luck with these channels on 1 degree west.
this not work.....has it something to do with the 8psk?
11421 h s25000 DVB-S2 - 8PSK MPEG-4/HD Conax
this work great for me.
11389 h s24500 DVB MPEG-4/HD Conax
chl
yes, of course :bye: ..but I can't see in my crystal ball whether you've got a DVB-S2 tuner/demodulator :blink:
Hi
I have the twinhan dvb-s2 card.......it just that i cant tune in the cannels with 8psk in DVBViewer......it works in Digital TV app that comes with twinhan....i can chose 8psk when tuning channels.
all other HD channels work fine.
chl
Edited by chl
Got it work now.....i use transedit so now it works...
Thanks
chl
Thanks
chl
excellent.
By the way have you tried the diseqc 1.2 facility?
does diseqc 1.2 work well with this card?
would you recommend this card over the tt 3200?
do you use this card successfully with any other dvb software?
cheers
excellent.
cheers
Hi
I only use diseqc 1.1 with 4 lnb so i have not test diseqc 1.2.....but i can test it later i have a motor connected to my second dish.
My friend has the tt 3200 and both card working.....it is hard to tell if any is better...my friend and i building our first htpc so we dont know so very much yet...
Just now we testing geforce 8600 gt and radeon hd 2600 xt to se which to use.
I have only run the card with digitaltv 3.3 (comes with the card) and DVBViewer pro......
my test so long in windows xp
Twinhan AD- SP400 CI dvb-s2
Geforce 8600 gt
Forceware 165.01
PowerDVD Ultra
DVBViewer Pro
Cpu usage on HD channels 5-20%
Hardware accelerate working
Radeon HD 2600 XT
Display Driver 7.7
PowerDVD Ultra
DVBViewer Pro
No test in vista yet.
/chl.
Edited by chl
I only use diseqc 1.1 with 4 lnb..
..which is d1seqc 1.0 :bye:
Yes it is 1.0....not 1.1 that i wrote.
chl
Edited by chl
