guardian24 Posted July 26, 2007 Posted July 26, 2007 (edited) Hi.. I have this annoying problem. DVBViewer wont play any dvds at all. I have necessary codecs installed. for audio and video, but no matter what i do i cant make DVBViewer to start dvd playpack. It worked before just fine (tried last time about 3months ago.) After that i had install everything again, when windows was messed up. I have latest stable version of DVBViewer and i use ffdshow for mpeg2 (in dvd coding option) and cyberlink for dvb stream coding (have also tried cyberlink codec for dvds). I have tried to select audio / video recognition on and off, it didnt make any change. When i use Cyberlinks Power DVD software everything works just like a dream, but with DVBViewer comes issues. Also windows media player works while using FFDSHOW. Does anyone have any clue what i m missing in settins? I know that DVBViewer is capable for dvd playback and i know that this isnt a bug in DVBViewer, but i just cant find the correct setting to modify. If it makes any difference i m using overlay renderer (have also tried other renderers without results.) Edit. Sorry guys.. It was my own bad.. just like i tought.. i just changed the codec from dvd options away from system default to cyberlind and now everything works just fine.. Edited July 29, 2007 by guardian24 Quote
Lars_MQ Posted July 26, 2007 Posted July 26, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Griga Posted July 26, 2007 Posted July 26, 2007 ...and enumerate all entries that appear in the View -> Filters menu when you try to play a DVD. Quote
