Maketee Posted July 28, 2007 Posted July 28, 2007 (edited) Heres the problem: -start DVBViewer -open channel list (K) -tune channel, that does not have epg data -open the epg window (E) -epg window is empty -> screenshot. now if you: -tune channel, that has epg data -epg windows doesn't show station list and if you continue to: -tune channel that do not have epg data -epg window doesn't update -mouse cursor shows "busy" and stays "busy", until i select channel that contais epg data And sometimes when i open channellist window, it shows empty *DVBViewer Pro 3.6.4.30 Beta RC2 *Windows Vista Ultimate x64 *FloppyDTV-C *Lumo-TV DVB-C Finland edit: I reinstalled DVBViewer and uploaded new support.zip support.zip Edited July 28, 2007 by Maketee Quote
Maketee Posted July 28, 2007 Author Posted July 28, 2007 More problems.... -start DVBViewer -open EPG window -select channel that has epg data -> it shows info in details screen -select channel that do not have epg data -> shows nothing in epg window (it should still show epg data for programs that starts later...) -select channel that has epg data -> it shows nothing in details screen! Quote
Maketee Posted August 1, 2007 Author Posted August 1, 2007 Works fine in beta versio 3.6.4.36. Thank you! Quote
