0x80040218 Problem with Artec T14 DVB-T
Morte
Hello everybody!
I have a this kind of a problem with Artec T14 USB DVB-T stick with DVBViewer 3.6.1.20
"Mediafile couldn't be rendered, error: 0x80040218 (No combination of filters could be found to rend.."
I can hear the sound, but I can't see the video
What might seems to be the problem and solution?
My system is follow:
AMD Athlon 64 4000+
Asus A5N8X (nForce 4, driver version 6.86)
1GB DDR
nVidia GeForce 7600GT (forceware version 162.18)
Artec T14 USB DVB-Stick
Sound Blaster Audigy 2
Installed codecs:
ffdshow rev.610 [2006-12-01]
AC3Filter
Here is a screenshot of DirectX settings of DVBViewer
Edited by Morte
Problem solved! I installed K-Lite codec pack. You can remove this topic or lock for future tips. >_<
The tip:
If you want to ruin your windows Directshow system and get problems without end, install a codec pack.
