Dvbviewer restart with Scheduler
chrispazz
Hello.
I noticed something strange when using Scheduler to handle restart of DVBViewer after standby of my PC.
Sometime, when I wake up my PC after hibernation, DVBViewer does not start. If I start it manually, it starts ok. Or, if I hibernate and wake up the PC again (with DVBViewer closed) it starts correctly.
Where can I look for solving this problem?
Could it be DVBViewer that does not close correctly?
I have set DVBViewer to restart after 5 seconds after wake-up (in scheduler settings).
Thank you.
Chris
Did you know, Scheduler does only restart DVBViewer after moving the mouse oder using the keyboard after wakeup
Have you tried a longer time (e.g. 10 seconds)?
Hi Hartwig,
I didn't know. I can try this evening with a longer time (10secs).
The only problem is that starting the pc from hibernation and waiting for other 10 secs could be a long time.
Do u know any others way to restart DVBViewer on wake up?
thank you
Chris
maybe...
Try to change the value for "DVBCloseDelay=" inside scheduler.ini to a higher value. For example 7000 (=7 seconds). Than DVBViewer will have a little bit more time before hibernation or standby.
Yes, its a little bit long. Normally it only prevents you for hardware trouble doe to driver initialization.
If you don't want to wait for mouse or keyboard action, add "RestartAutomatic=1" to Scheduler.ini into the section [frmScheduler]. :blush:
But notice, if your PC wakes up accidentally, it will not go back to standby/hibernation automatically due to the running DVBViewer. DVBViewer starts without any mouse or keyboard event.
If DVBViewer doesn't start automatically, have a look at the taskmanager. Is "DVBViewer.exe" still running?
I have added restartautomatic and also raised CloseDelay to 8 secs (it is not a problem if it is slow to hibernate).
Now it seems to wake up correctly but I see next times.
For now, thank you very much for your support!
Christian
Hi Hartwig,
the problem seems to be still here.
I noticed that if I wake up pc after a little time (say some minutes), DVBViewer starts ok.
If I hibernate pc in the evening and wake up it the following day, it does not starts.
Today, after being waken up, I pressed OK on my MCE remote and DVBViewer has been fired up.
Pls take care that my HTPC do not have keyboard or mouse connected. Only MCE usb receiver.
It seems that the automaticrestart setting in scheduler.ini has been ignored.....
Thank you
Chris
Have you edited the right Scheduler.ini.
Depending on your usermode in Usermode.ini, the right scheduler.ini will be on different places.
But it's easy to find the right one. Start DVBViewer, go to Help / Info / Version Info and click on the blue link. There you'll find it.
And is the new entry in the right section?
[frmScheduler]
RestartAutomatic=1
Here it is my scheduler.ini:
[scheduler]
Username=[removed]
Password=[removed]
[frmScheduler]
RunAfter=0
Left=245
Top=208
Width=336
Height=319
cbAutoSchedule=All
cbScheduleOnStart=1
cbScheduleOnClose=1
cbScheduleOnSuspend=1
cbContinueWith=Default
cbCloseOnShutdown=1
cbDontTune=0
cbAutoMinimize=1
udLeadTime=2
edSpecialParam=-c11
edBefore=
edAfter=
edSleepTime=0
DVBStartDelay=2500
DVBCloseDelay=3500
ScheduleDelay=2000
DVBRestartOnResume=8
Launcher=Scheduler.exe
LaunchedFile=DVBViewer.exe
cbStartMinimized=0
RestartAutomatic=1
[General]
Version=2.1.0.0
yes, I am sure is the only one (and the correct one).
Thanks
Edited by Tjod
Username and Password should not be published
  • 1 month later...
Hi there!
Have you solved this somehow? I'm suffering samekind situation and I haven't found solution anywhere.
My problem is:
- When I hibernate PC with remote (I never shut down it) it hibernates fine.
- After wakeup DVBViewer doesn't start even if I move the mouse. I have to start it manually.
- Timed recording works fine when PC is running
- Timed recording when PC is hibernated: PC starts in right time, desktop opens and it hibernates after right time, just like I wanted, BUT nothing is recorded!
Intel P4 2.4 GHz HT
1 Gt RAM
Windows XP Pro
Hauppauge Nova-T 500 PCI
DVBViewer 3.8.0 (in Windows startup-folder)
DVBTaskScheduler 2.1.0
Settings:
- Schedule NEXT...
- When DVBViewer closes
- On StandBy/Hibernate
- Continue with Hibernate
- Auto-Minimize DVB Task Scheduler to Tray
- Restart DVBViewer Without tuning last channel
- 1 minute lead time
- 5 sec. Reastart on resume
No username/psw used (settings are as in Task Scheduler's readme)
No firewalls/virus scanners
In DVBV "use Microsoft task..." is set.
In Scheduler.ini "RestartAutomatic=1"
Usermode=2
I'm wondering what I have missed, any suggestions?
Thanks!
