lateko Posted July 31, 2007 Posted July 31, 2007 Hi, Having some trouble with some options to get saved. When I start DVBViewer it always starts it from certain channel. Earlier installation always remembered last viewed channel. Also window size is now always 50% even though i never use it. Furthermore for example when I change epg info window appear time from settings it is back to default value 4 after i restart viewer (but if i change it manually from settings.xml file it works fine). I have access to write into settings.xml and I've also tried to delete it but that's not helping. Any ideas? Quote
