jhj2000 Posted July 31, 2007 Posted July 31, 2007 Hi, I have a KWorld DVB-S 100 card which is working perfectly with DVBViewer. I'm trying to get its remote control working. Is it possible? I've noticed that when I press the 'Power' button on the remote DVBViewer pauses the feed and when I press it again it restarts. Any help will be appreciated. Thanks John Quote
Tjod Posted July 31, 2007 Posted July 31, 2007 It seams that the remote works already. You can try to Learn the commands from your Remote Control. Options > Input - > Learn -> select the command -> pres the remote key. Quote
