jimwillsher Posted August 4, 2007 Posted August 4, 2007 Hi all, The list of tuners on the website, is that 100% accurate? I'm looking to see if DVBV supports the Aver A808 Volar DVB-T tuner. I'm current using until Media Center in Vista x64. Many thanks, Jim Quote
hdv Posted August 4, 2007 Posted August 4, 2007 Hello, here is a other list with supported DVB-Devices, http://www.steffen-klausing.de/content4/fa...&artlang=de You can make a test with Transedit MMC (Download) if your DVB-T tuner is working. After starting, take a look at Settings -> Hardware if the device listed. Now you can use at left side one of the Terrestrial transponderlists and chose one the right "Scan All". The scan should find channels, so then DVBViewer will work. Quote
jimwillsher Posted August 4, 2007 Author Posted August 4, 2007 Many thanks for the extremely quick reply, much appreciated! I've downloaded and run Transedit. The device is correctly listed. However I'm not sure which transponder list I should use? I'm in Scotland, UK, and use the Craigkelly transmitter for "Freeview". Can you advise? Many thanks, Jim Quote
hdv Posted August 4, 2007 Posted August 4, 2007 Hello, i have found this site, http://www.linuxtv.org/pipermail/linux-dvb...ust/004172.html so you must use the list "Terrestrial (EUR)" in the right you can now select the 6 transponders from the link and then click "Scan selected" Quote
