50Hz noise in audio signal
Benarty
The mediacomputer is directly connected with it's audio out (on-board alc880 contrtoller) to a audio input of scart connector. The computer is gounded properly but still , there is a 50Hz noise signal mixed in the audio signal.
A standard stereo audio cable is used.
is there a way to avoid the noise?
..you could try a ground loop isolator.
I did buy one today from a friend and yes, problem solved.
Thanks alot Derrick.
Edited by Benarty
