JoacimNitz Posted August 7, 2007 Posted August 7, 2007 Hi, new here! This application is amazing! Everything worked the first time i installed it! =) I read that there is a Windows Media Center controll plugin. But is there anyway that i can add my Remote that came witht the Zalman HD135? Some of the buttons seems to work. I.e the ENTER button. But not the directions? And if not. Is there a way to "enter" the skinned EPG by using the mouse/keyboard? The only EPG i can show is the default one.? Thnx Joacim Quote
Tjod Posted August 7, 2007 Posted August 7, 2007 If some buttons work you could try to learn the other buttons in Options > Input (Learn > select the command > press the remote key). OSD-Menu could be open with ESC to or you activate Use mouse sensitive areas (Options > OSD Apearance) than you could open OSD by click on the left, wright or the bottom of the TV picture (each time a different one). Quote
