arc03 Posted August 7, 2007 Posted August 7, 2007 (edited) Hi all. I have used DVBViewer with success till I updated from 3.6 to 3.8. First I uninstalled 3.6 from my computer and installed 3.8. Then I made a new .ini file inside Transponder file. I tried to scan channels with this .ini file, but could not find it from drop-down box... And it is in Transponder file. Tried several times with no luck. Then I tried to go back to 3.6 but again, no .ini file found from drop-down box. Now I can't watch fta programs... Has something changed regarding Transponder file and its usage? How can I uninstall this program so I would start from fresh? I tried it with windows install/uninstall, but after reinstalling my previous settings was already there. Thanks for your help in advance. EDIT: Problem solved. Have to start the program and from "About" , "configuration folder" you open Transponder file and save a new .ini file there. Edited August 7, 2007 by arc03 Quote
