Pawel Posted August 8, 2007 Posted August 8, 2007 First of all many thanks for the great and stable program. My request is perhaps a secondary but I'd like to ask for a "Timer" on the icon toolbar, instead only a link from the pull down menu. I use "Timer" window heaps of times because a few channels from which I used to record don't have EPG - hence I have to insert tasks manually. An icon would be handy. Thank you, Pawel Quote
Tjod Posted August 8, 2007 Posted August 8, 2007 You could build a shortcut with ...\DVBViewer.exe -x33 to open the Timer Window. Maybe it helps you a bit. Quote
Pawel Posted August 9, 2007 Author Posted August 9, 2007 (edited) Thanks but I will wait for an icon I added a keyboard shortcut so I'm helping myself Edited August 9, 2007 by Pawel Quote
