duja Posted August 8, 2007 Posted August 8, 2007 Well, dont think that I have to include a support.zip about this problem. The record folder will not be changed if you change it in the wizard, the default one will be used. Also It would be great to include the "Send only encrypted channels to CI" option in the hardware section of the wizard. Hope I did post this in the right forum. / Duja Quote
Tjod Posted August 8, 2007 Posted August 8, 2007 The record folder will not be changed if you change it in the wizard, the default one will be used.I had it only one time (by making more than 30 installations) will Testing the Setup.So i could not find out in witch situations it happened. May be someone else is able to find more in witch circumstances it happens. So that it could be fix in a future version. And "Send only encrypted channels to CI" i think will not be included in the wizard because only some people need it. If every Option will be included, that may be some one need we have to include the entire Options dialog. Quote
Lars_MQ Posted August 8, 2007 Posted August 8, 2007 Send only encrypted is NOT advised. This is a setting which should only be activated, when you are asked to. Quote
duja Posted August 12, 2007 Author Posted August 12, 2007 Send only encrypted is NOT advised. This is a setting which should only be activated, when you are asked to. Okey I'll understand. Quote
