JayKay Posted August 8, 2007 Posted August 8, 2007 (edited) Hi, I am a real newbie, and am trying to do this right.... I just purchased the Pro viewer. PROBLEM:After installation, no channels are found. WinTv2000 does find the channels, software which came with the Hauppauge tuner (but this software sucks..) I updated the drivers (http://www.hauppauge.co.uk/pages/support/support new_xpvista.html) of june 2007. DVBViewer noticed the hauppauge hvr1300 tuner after installation and also when running, but it will not scan channels. I will give the pop-up: "No harware available" What am I doing wrong?? I added my system info in TXT file EDIT: ALSO THE SUPPORT FILE WAS ADDED please help, Jan DxDiag.txt support.zip Edited August 9, 2007 by JayKay Quote
Lars_MQ Posted August 8, 2007 Posted August 8, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
JayKay Posted August 16, 2007 Author Posted August 16, 2007 I added the requested file and fiddled around in the settings, but no sucess. I think it is a driver problem. I really want to use this viewer, since it seems(still) better than my old one. PLease help, Jan Quote
Lars_MQ Posted August 16, 2007 Posted August 16, 2007 You did select the correct tunertype in the scanning window and a fitting transponderlist? Quote
JayKay Posted August 17, 2007 Author Posted August 17, 2007 Yes I did, but if I hit the scan button, it does not scan...no matter what list I would take. I tried to upload a screenshot of the screen, but it does not let me. Jan Quote
