pfugl Posted August 9, 2007 Posted August 9, 2007 I have searched through the forum, trying to find out where recording timer settings are saved. I found some references to TIMERS.XML. However I cannot find it anywhere on my PC. Have I misunderstood something? /Peter Quote
Lars_MQ Posted August 9, 2007 Posted August 9, 2007 DVBViewer -> Info -> Config folder -> timers.xml Quote
pfugl Posted August 9, 2007 Author Posted August 9, 2007 DVBViewer -> Info -> Config folder -> timers.xml Sorry, but I am not quite sure what you mean by this. Are you talking about the dropdownmenus, or directory structure? I do not have any Info directory under my DVBViewer directory. I have searched the entire pc for timers.xml, and it is not found. My timer recording works ok - I just need to read the contents of this file in another program. Peter. Quote
Tjod Posted August 9, 2007 Posted August 9, 2007 Go in the DVBViewer > Info > Config folder that will open the folder where your Config files including the timers.xml are saved. Quote
pfugl Posted August 9, 2007 Author Posted August 9, 2007 Go in the DVBViewer > Info > Config folder that will open the folder where your Config files including the timers.xml are saved. Ok - found it - Thanks. Peter Quote
