DVBViewer Pro 3.8
omkaradag
hi, i'm using MS Vista OS, and i'ev purchased Technotrend S2 3200. Pro 3.8, and it's great. But i've got a problem
There isn't EVR renderer, there is WMR9 bu it work only 30fps in h.264 broadcasts and also utilizes CPU very much.
There is EVR in GE, but ******* doesn't seem to work with it.
Could you please add EVR Renderer to DVBViewer pro, that would make me very happy
thanks
Edited by Griga
@omkaradag: Your post has been moved to here. Please post in the English section of this board, if you want to write in English, and above all, respect the forum rules. Otherwise your account will be cancelled.
And only Post one Time for Problem not 3 times. We did not like Crossposting.
Thanks and sorry. :(
EVR in DVBViewer Pro is very unlikely.
As for now there are three options for you:
- Use the GE Version with EVR, but without CI support -> no encrypted channels
- Switch to WinXP, hardware acceleration of h.264 streams works with VRM9.
- Wait for the Direct3D Renderer to be finished (could take some time).
