SamAlone Posted August 10, 2007 Posted August 10, 2007 When i shutdown the program the process keeps running and the sound keeps running ?? I need to shutdown process to be able to shutdown the program. Im running Vista Ultimate 32bit version, program is installed under c:\ tried run as admin but still the same issue on shutdown. Any help here would be prusiated. Thx ! Quote
Lars_MQ Posted August 10, 2007 Posted August 10, 2007 Please remove all plugins (or rename the plugin folder). Does it happen then? Quote
SamAlone Posted August 10, 2007 Author Posted August 10, 2007 Please remove all plugins (or rename the plugin folder). Does it happen then? Thx, i will try later today, but shouldnt [deleted] work ? Or is there any known issues with those perhaps. Thx again, i will get back after tried ur suggestion. Quote
Lars_MQ Posted August 10, 2007 Posted August 10, 2007 respect the forums rules. No support for illegal stuff. Quote
SamAlone Posted August 12, 2007 Author Posted August 12, 2007 respect the forums rules. No support for illegal stuff. Sorry about that.. and yes it was the plugin causing this problem, guess i wont get any solution to it then. Thx anyway. Quote
