k1509 Posted August 10, 2007 Posted August 10, 2007 Hi I am using DVBViewer ver 3.6.1.20 and want to import a new ini file scanned with Transedit, but I am doing somthinh wrong. This is what I did. Scanned with TrandEdit, saved it as ini file. Opened DVBViewer, opend ChannelEditor In network Root typed a new name clicked on import button and selected the file created with Transedit. Clicked on save button and on Close Open CanelEditor again, but I can not find the new one just imported, so I have done somethinh wrong. What is the correct procedure. Have looked in help, but did not fine much. rgds Quote
Tjod Posted August 14, 2007 Posted August 14, 2007 Do you use TrandEdit from the Members Section? Have you put TrandEdit.exe in the DVBViewer folder? Than should the right click send to DVBViewer work. Quote
