Internet radio
accolon
How do I set up DVBViewer to play internet radio streams such as shoutcast?? Preferably so I can use the OSD to start the streams!
Thanks beforehand
Accolon
You have to build .murl files.
977 Hitz Channel.murl
[InternetShortcut]
URL=http://64.236.34.97:80/stream/1074
Description=.977 The Hitz Channel
and if you put a 977 Hitz Channel.jpg in the same folder it will be shown as icon.
Than add the folder in witch the *.murl files are to Options > Music VirtualPath.
Now you could open them via htpcHome > theMusik
Here you will find some examples.
I have tried this but can't get it to work. DVBViewer hangs, starts showing visaualizations but no sound or complain about a missing filter.
Do I need some kinde of special filter to recieve shoutcast??
Edited by Tjod
Pleas do not Quote hole Posts.
I did not checkout if the URL is still right. :P
URL=http://scfire-chi0l-1.stream.aol.com:80/stream/1074
souled work now.
How to get the URL?
Go to http://www.shoutcast.com/ download the shoutcast-playlist.pls open it with Notepad and chose one of the URLs.
I tried this aswell but to no awail! I have a router maybee I need to forward some ports?
No i use a Router to and have no port forwarded.
Witch Filters are listed while such a stream is open (View>Filters> )?
Yes it was some kind of filter mess..... I need to cleanup my filters i guess
Thanx
  • 1 year later...
Hi, thanks for this but how do I get the radio stations logo to be viewed?
If the file name is 977 Hitz Channel.murl put the logo as Hitz Channel.jpg in the seam folder.
This is what I have it simply wont show a logo in Music Folder on HTPCHome
Cheers
WCBS.zip
Edited by remlap
Here it works (3.9.4.0 and 3.9.4.110), you have to converted the images.
Renaming is not enough.
You have selected "Listview" click on the Icon beside Listview to change to Small or Large Icons.
What are the correct dimensions needed to fill out the CD case, because its working now :)
  • 5 months later...
ehmm
Maybe I don't undetstand the above at all..
is it possible to play a forexample this link, stream, or what ever to call it, using DVBViewer?
http://planetrock.radica.com/listen-again.htm
and if then how to... ?
If the question is stupid.. them pls forgive me..
:blush:
If not possible, It could be a great funcktion thing to add.. and also streamning video from the web.
if possible at all of course..
Thanks beforehand
Accolon
IMO it would be easier for you to use a site such as Reciva, Pure Lounge, Vtuner in a browser and set up VLC player to play m3u and wma files - you may also need to select vlc to open asf asx and m3u links in your browser options.
