Disable av turing recording via Timer
bob0r
Disable av turing recording via Timer in DVBViewer 3.8.0.0 fails.
It worked fine in 3.6.1.20.
Anything i have to change in settings or bug?
Neither. A change. close the graph an it will not tune a channel if you use disableav in timer.
It does work together with the close graph function.
Ok Cool, ill try find that option later, thanks!
if you are autostarting DVBViewer with task sheduler or something like that, just untick "tune last channel on start" in Options -> TV + Radio.
Close Graph is in the View Menu. You can add a keyboard shortcut for it or similar, too.
OK, i am indeed autostarting from scheduler..... "tune last channel on start" <--done, now pray it does indeed record the program :mellow:
THANKS!
