tryhard Posted August 11, 2007 Posted August 11, 2007 Hello, is it possible to use the COM interface to perform a fastforward for a certain number of seconds ( input parameter) when playing a recording ? I know that I can do a fastforward for certain intervals specified in the setup.xml (jumptime), but I would really need the number of seconds as input parameter. With this you could for example implement an advertising treatment as implemented in VDR ( e.g. use noad to determine marks/times at the beginning and end of an advertising block, store them in a file and use them to jump to the end of the block) regards Quote
patti Posted June 20, 2010 Posted June 20, 2010 I would be interested to know too if this is possible. But since it's been nearly three years without a reply I suppose it is not possible? Is the jump +/-XX seconds a hard coded feature without a possibility to change on the fly? patti Quote
