Technotrend S2-3650 HDTV-S2 USB+CI
Imbalanced Zero
TT app installs and requires normal VC 2005 runtime. In order to get the API-DLL working, you need VC 2005 SP1 runtime!!!
Get it here for x86 machines: click
Edited by CiNcH
Right, you need a properly installed VC2005 runtime...
YES :
work great with the "Package redistribuable Microsoft Visual C++ 2005 SP1 (x86)" (SP1 needed)
I'm testing now with my old technisat skystar 1.1 as second receiver.
Is there any chance of having twice channels decoding ?
OutOfTopic add : (ttapi.dll is no more installed with a fresh DVBV 3.9)
thanks for all...
go back testing on HTPC (#2) ;-)
Of course it is. have a look at the downloadsection of the setup. You have to select it to install it.
Thanks a lot ,now it's working.Will record a HDTV movie and check if it's running without freezers.
Hello
My configuration: Windows Vista + TT USB2 S2-3650 + CI +CAM Aston + subscriver card Canal Satellite (France)
I have installed DVBViewer last version
I have installed MS VC Runtime
I have installed ttBDA api dll under the DVBViewer repertory (D:\DVBViewer)
I can receive the free channels
I can't receive the crypted Channels (but they are in the channels list)
I don't see anything in the window "See Commun Interface and CAM".
Can you help me?
Thanks
Edited by Colnem
You are hopefully running latest DVBViewer 3.9?
Does the TT software decrypt channels?
Did you install SP1 of the VC 2005 runtime?
1 - Yes, I have bought DVBViewer yesterday (I send you a mail the day before)...
2 - Yes, crypted channels run with TT Mediacenter
3 - Yes, i have selected VC 2005 runtime at the install. I saw the download and the execution of VC 2005 runtime...
I have also selected add on for the TT cards. the TT Api dll is under the DVBViewer repertory....
I have selected the option "with CI" in the item hardware for my DVBS-Card...
4 - my driver version is 1.0.2.11 (the latest for S2-3650)
4 - If have uninstalled and reply the install, with the same options. Same problem.
Thanks
Edited by Colnem
Please also post the support.zip.
Christian
Is it SP1? I am not sure...
there is two vc runtime redist.
the good one is SP1 !
Hello
I have installed this who is linked on this forum...
How do I proceed to create a support.zip?
Thanks...
Edited by Colnem
Hello
I tryed to day with my second PC, OS= Windows XP2
Pilote TTS2-3650 1.0.2.11
VC runtime loaded by DVBViewer Wizard
dll ttBdaDrvApi_Dll.dll under the DVBViewer main repertory
Same problem. Free Channels OK. Crypted channels none. The window "Commun interface" is empty: no cam detected...
Have you an idea?
Thanks
I am really clueless. I have now checked which VC runtime is being downloaded and installed by the DVBViewer installer, and it is SP1, so the correct one. Please check ttBdaDrvApi_Dll.dll version. It has to be 1.0.1.11.
Did you select the x86 version of VC runtime? Applies to 32-bit operating system... Don't select both, select the one that applies to your operating system (64-bit = x64; 32-bit = x86).
Edited by CiNcH
"Did you select the x86 version of VC runtime? Applies to 32-bit operating system... Don't select both, select the one that applies to your operating system (64-bit = x64; 32-bit = x86)."
Yes, only 32-bit...
"Please check ttBdaDrvApi_Dll.dll version. It has to be 1.0.1.11."
the version of my dll , loaded by DVBViewer, is 1.0.1.4
Christian posted 1.0.1.11 in this thread!!! You need this one!
Download
Please guys read the things written here!
Edited by CiNcH
Sure boss, is better...
I'm sorry, I thought that the download install load the good version of this dll. I have not verify the version...
So, I valid DVBViewer with TT S2-3650 + CI + CAM Aston for french crypted channels CanalSat.
Thanks for your contribution.
  • 3 weeks later...
Download
may be a windows xp post sp2 update, but, now :
I have some few channels which show badly.
I'm using 3.9.1 with latest intel chipset and latest technotrend driver BDA.
my 3650 USB CI use with a matrix and sometimes channels have few "square" or "lines".
like the "directshow update" problems !
may be a problem in the graph ?
the cam no more show inside the menu (when selecting items)...!
so the 1.0.1.11 is not at all completly working !
FTA is okay.
What do you mean by "now". So it has worked already, now it doesn't do its job properly any longer? Why do you blame the TT-API then?
TTAPI or DVBV but; in facts: the version 3.9.1 don't show channel correctly : some hang on images, few decryption problem...
the decryption is still there but seem to be not fast enought ? (or may be another problems, but from ttbdaapi).
the menu cam interface do no show anything else that the menu (sometimes)... not possible to go inside.
try all codec : the same.
try a different cam : the same.
try back version 3.9.0 : the same.
is there an update from microsoft that I need (or which is in cause of troubles).
for me it work as a beta, few fonctions with less quality... :bounce:
very disapointed !
Well the tt dll IS beta.
if I can do some/more test...?
just ask :bounce:
thanks...
Hi there,
I'm testing the new API, too. After Installing the VC2005SP1 Runtime, the CAM works also fine! I own a TT budget 3200 CI, using Driver 5.0.0.6.
But the best of the new API is: NO MORE DISCONTINUTIES!!!! ;)
Now I could watch HDTV without any errors. :blink:B):wacko:
Discovery HD is running now about 2h without any discontinuties. With the old API I had every minute 1 or 2 discontinuities. If I reinstall the old API, the disc. are back.
i've also installed the version 3.9.1.1 at the weekend with the CAM plugin.
Everything worked fine. Premiere, Premiere HD, ORF.
But suddenly i've got a freeze on ORF and all crypted channels didn't work anymore.
Restart of the PC, everything fine again.
Anyway, the performance of this software is way ahead of the original one.....
do not seen that it was an updated 3.9.1.1 (still viewed as 3.9.1.0) !!!
made the update, put the "beta" bdadll.
made all update from microsoft (dot net sp1 and dot net 3)...
everything seems to works great again !...
needed updates ?
thanks for all ;)
needed updates ?
thanks for all ;)
in 3.9.1.1 with the above updates; menus of cam interface works again :blink:
good news :wacko:
  • 1 month later...
May I have your confirmation that is necessary to install this runtime component in Windows Vista
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
for the correct functioning of the ttBdaDrvApi_Dll release 1.0.1.11 for the DVBViewer 3.9.1.1?
tks
Sergio
  • 7 months later...
I can't get remote work !
ttDVBs2-3600USB
test everything ! any hints?
my Computer is MAC Pro:Quad Xeon 2.8, 2GB memory ECC 800 ,
with BootCAMP (not Parallel windows)
Edited by AjeeB
- check whether the ttBdaDrvApi_Dll >= Version 1.0.1.5 is present in the DVBViewer folder
- check whether VC2005 SP1 is installed
- download the TT remote plugin (1.1.1a) from the members section and copy the plugin to the DVBViewer's plugins folder
- [iMPORTAND] read the readme included in the TT remote plugin package, you have to learn keycodes and assign actions!
What about adding this to the wiki? Or is it already there? I am tired of repeating it every month for remote and CI..
Edited by CiNcH
