chrispazz Posted August 14, 2007 Posted August 14, 2007 Hello. Is it possible to change the time shift file size? Thank you Chris Quote
Lars_MQ Posted August 14, 2007 Posted August 14, 2007 It does change all by itself. The more timeshifting you do without changing channels the bigger it gets. Quote
Tjod Posted August 14, 2007 Posted August 14, 2007 DVBViewer do not use a ring buffer. It is recorded until there is not enough disk space or you change the channel or stoop it. Quote
chrispazz Posted August 14, 2007 Author Posted August 14, 2007 (edited) Thank you for your answers. I was asking this because I noticed that after a while (about 10 mins) that I am looking a HD channel I get one single stutter. Then I get another one every 20 or 30 secs. I tought it was the timeshift file that was too big but I tried to switch off timeshift but is the same. I also tried to switch from overlay to VMR but is the same. Where can I look for what is causing this stutters? I also loose ac3 audio for 1 sec during the stutter.... Thank you Chris Edited August 14, 2007 by chrispazz Quote
Nils-H Posted August 30, 2007 Posted August 30, 2007 A ring buffer would definitively be nice! Any chance this will happen in a future release? Quote
Lars_MQ Posted August 30, 2007 Posted August 30, 2007 No. There are several posts in the forum explaining why. Quote
