subdvbv Posted August 15, 2007 Posted August 15, 2007 Hi Everyone, I am still undecided as to which s2-dvb card is best for me. If anyone can provide me with the following info it would be of help 1. Are the CI interfaces of the following cards working under DVBViewer 3.8 a ) Technotrend s2-3200 b ) Twinhan s2-dvb / Azurewave sp400-- (Twinhan 1041) c ) Techonotrend s2-3650 USb 2. if so what cams have you got working with official cards 3. which card a,b, or c do you rate as being the most stable and problem free 4. as the support for diseqc 1.2 improved for the above cards under DVBViewer 3.8? ie do the above cards work with a HH120 Stab motor? 5. Are there any s2-dvb tuning issues with the above cards 6. What version of codecs have given you the best results with the above cards 7. as anyone encountered any performance/ picture quality issues when using the usb s2-3600 or s2-3650 once again thanks for your wise words. ps. sorry if some of these questions have already been asked elsewhere in another way. Quote
thehawk Posted August 15, 2007 Posted August 15, 2007 I'm also on the same boat so I would also appreciate some answers Quote
Lars_MQ Posted August 15, 2007 Posted August 15, 2007 1. a. yes b. yes c. not yet. 2. alphacrypt classic and alphacrypt light (user confirmed) 3. 1.b. 5. 1.a. has issues. 8. do not use vista. stick with xp Quote
thehawk Posted August 16, 2007 Posted August 16, 2007 Hi Lars. I understand you recommend Twinhan s2-dvb for HDTV then? Quote
djdul Posted September 17, 2007 Posted September 17, 2007 1.c. not yet. is there a (near) time preview ??? I own a technisat and a (now) a technotrend connect 3650 (too) but the cam is useless (as you know) ? for sure; I'm ready for testing ... thanks and happy coding. Quote
thehawk Posted September 17, 2007 Posted September 17, 2007 Is the FloppyDTV DVBS2 supported under DVBViewer, including CAM support? Quote
Benarty Posted September 20, 2007 Posted September 20, 2007 Is the FloppyDTV DVBS2 supported under DVBViewer, including CAM support? Yes, the floppy DTV DVB-S2 works under DVBViewer. Once installed, load the latest firmware of the DVB-S2 for digital everywhere's website. CAM is supported, no need to run the CI console. Some report problems when using two floppy DTV's in one system. The firmware update should fix that but still some having still problems. the DVB-S2 alone has no problems at all. Quote
thehawk Posted September 21, 2007 Posted September 21, 2007 Ouch, I intend to have two of these in my future system. Quote
Benarty Posted September 22, 2007 Posted September 22, 2007 Ouch, I intend to have two of these in my future system. Two of them work also as long as the firewire port is not causing problems..but, hey the floppy DTV-S2 has a ....firewire repeater. Quote
thehawk Posted September 22, 2007 Posted September 22, 2007 I'll start my HTPC build next month, undecided between two of these or two 3200s. Having said that, I read that Digital Everywhere offer better support so will probably opt for them. Quote
subdvbv Posted October 8, 2007 Author Posted October 8, 2007 I'll start my HTPC build next month, undecided between two of these or two 3200s. Having said that, I read that Digital Everywhere offer better support so will probably opt for them. Hi Everyone, here is an update to my initial enquiry. After some thought I decided to go for the Digital Everywhere floppydtv s2 firewire card.. and it as been excellent. It works as well as my old SS2 card and is as fast even when switching between HD channels ! Having had the card for only a few days I am glad to say that so far the performance , with DVBV ver 3.9, as been faultless. My next task is to set up DISEQC but I cannot find any documentation to help with this - I have a HH120 Stab motor- can anyone help? Thanks everyone. Quote
Benarty Posted October 8, 2007 Posted October 8, 2007 Hi Everyone,here is an update to my initial enquiry. After some thought I decided to go for the Digital Everywhere floppydtv s2 firewire card.. and it as been excellent. It works as well as my old SS2 card and is as fast even when switching between HD channels ! Having had the card for only a few days I am glad to say that so far the performance , with DVBV ver 3.9, as been faultless. My next task is to set up DISEQC but I cannot find any documentation to help with this - I have a HH120 Stab motor- can anyone help? Thanks everyone. FloppyDTV supports Disecq 1.2 but no usals yet. Which means it can control a rotor. You need a disecq switch to split the signal between LNB and HH120 I don't use a rotor but multiple LNB setup that point to 3 astra positions. No delay to turn the dish and no motor noise. Quote
thehawk Posted October 9, 2007 Posted October 9, 2007 For my future HTPC setup, I won't use the card to move the dish, but will keep the satellite receiver I currently use. Quote
ugo Posted October 10, 2007 Posted October 10, 2007 FloppyDTV supports Disecq 1.2 but no usals yet.Which means it can control a rotor. You need a disecq switch to split the signal between LNB and HH120 I don't use a rotor but multiple LNB setup that point to 3 astra positions. No delay to turn the dish and no motor noise. Hi This mean that with DVBViewer and the FloppyDTVS2 I can move the rotor (the mine is a generic 1.2 rotor that works with modded skystar 2 drivers)? Regards Ugo Quote
