dellfan Posted August 15, 2007 Posted August 15, 2007 Hi, I have these cards and one problem. DVB-S2 working only in "Ge" version of DVBViewer. If I've in Setting Option/ Hardware unchecked "Use standard inteface" DVB-S2 tunning working properlly. If is checked, is impossible locked freqs in DVB-S2 mode (QPSK and 8PSK). Also Transedit working too. But in DVBViewer Pro, what I planned using for viewing/recording for low rate of CPU, isn't this options, and working only DVB-S channels. Any else options setting not important and have not effect. Pls,Have anybody any Ideas, whats wrong? It's same in PC with PCI TT-S3200 and in notebook with USB TT-S3600. HW: Notebook - Dell D610 (PM - 1,73G, Ati 9000 32MB Ram) PC - P4 1,7G, NVidia 128M ---------------------------------------------------------------------- SW Orig. XP Pro SP1 (not using SP2, for problems with older drivers for Skystar2). I know, thats older hw, but Its not reason for tunning problems, I thing. Thanks. Quote
Moses Posted August 15, 2007 Posted August 15, 2007 TT S3200 should definitively work in DVBViewer Pro. Which version are you running? Quote
dellfan Posted August 16, 2007 Author Posted August 16, 2007 TT S3200 should definitively work in DVBViewer Pro. Which version are you running? Newest version 3.8.0.0. TT 3200 (budget): - In Windows XP Pro SP2 without problems, but in XP Pro SP1 I can't tunning DVB-S2 freqs. (CD BDA drivers version: 1.0.7.1, Date: 18.9.2006). I checked other versions of drivers, without effect). TT3600 (Conect USB): - I can't install drivers from original CD, needed XP SP2. Only one driver from their website. Working without problem, but without DVB-S2, again. It's same problem with an one orig. XP Pro SP1 on two PCs, two DVB-S cards. DVBViewerGe working properly (With option as I wrote in first post). First I thought, thats problem is in hw on my PC. Later, I purchased USB version for notebook and some problem as. Note: I've already installed older drivers for SkyStar2/SkyStar USB, On both hw (PC and notebook). I'm not a newbie, have about 20 satellite receivers, 8 PC-DVB cards. Regards. Quote
