AutoIt generated exe's infected! (False positive)
EDIT: I think this should have been posted in the "Scripting ..." thread. Right? Sorry :rolleyes: , please move.
Until now I have used the following script to import XMLTV EPG into DVBViewer.
(slightly modified version of a script by Mike Robertson)
#include <Date.au3>
Const $XMLtv_File       = "TVGuide" & ".xml"
Const $myXMLtv_Path     = "C:\Programmer\DVBViewer\"
Const $myXMLtv_Exe      = "myXMLTV.exe"
Const $myXMLtv_Window   = "DVBViewer XMLTV Import"
Const $DVBViewer_Path   = "C:\Programmer\DVBViewer\"
Const $DVBViewer_Exe    = "DVBViewer.exe"
Const $DVBViewer_Window = "DVBViewer"
;If not runnung, then Start DVBViewer & wait for it's window. Wait another x seconds
$WasDVBViewerRunning = WinExists($DVBViewer_Window)
If Not $WasDVBViewerRunning Then
 Run($DVBViewer_Path & $DVBViewer_Exe)
 WinWaitActive($DVBViewer_Window)
 Sleep(5000)
EndIf
; Start myXMLtv & wait for it's window.
; tab to the file name, key in the file name.
; tab to the import button & press it.
; Wait  for the import button to be visible again & close the window.
Run($myXMLtv_Path & $myXMLtv_Exe)
WinWaitActive($myXMLtv_Window)
Send("{tab}{tab}{tab}" & $myXMLtv_Path & $XMLtv_File & "{tab}{tab}{ENTER}")
WinWaitActive($myXMLtv_Window , "Import")
WinClose($myXMLtv_Window)
;If DVBViewer was not running then  Close the DVBViewer window
 WinClose($DVBViewer_Window)
EndIf
Suddently my AVG-antivirus began to detect all AutoIt-compiled exe'es as infected (False Positive).
I then decided to write a Delphi program doing the job.
(Oh,I hate my username! Didn't know DVBViewer was programmed in Delphi the first time I signed in. It's more than 10 years since I did any Delphi programming.)
One advantage of a Delphi program is that no folder names needs to be hardcoded.
The exe can be used as is by anyone. Usermode or Windows localisation doesn't matter.
Now to my Delphi programming questions (The exe will reside in the DVBViewer program folder):
1) How do I safely get the Path to the DVBViewer Config Folder?
I can find Usermode and Root in usermode.ini in program folder.
This is actually enough to know for now, but maybe in the future there is a Usermode=3 (shared folder on network? :( ).
It is OK to assume DVBViewer is running.
2) How do I (safely) close DVBViewer ? (se script)
Maybe in the meantime DVBViewer has fired a recording job.
Then maybe it should not be closed. Maybe it is OK to close if recordings Service is used.
Maybe it generally should not be closed at all?
In my case the import takes only a few seconds so it has been quite safe to use the above script.
Well, 10 years is a long time!:
3) How to detect if DVBViewer is running ?
Thanks in advance
Delphi (can I somehow change this?)
Edited by Delphi
just try the following:
var
 FDVBViewer: IDVBViewer;
function DVBViewer: IDVBViewer;
var
 Unknown: Iunknown;
begin
 if FDVBViewer = nil then
 begin
Unknown := nil;
if GetActiveObject(CLASS_DVBViewer, nil, Unknown) <> MK_E_UNAVAILABLE then
  Unknown.QueryInterface(IID_IDVBViewer, FDVBViewer);
 end;
 Result := FDVBViewer;
end;
If the result is NIL the DVBViewer is not running. All you also should do is to import the com library of the DVBViewer. The rest should be documented in the sdk.
Christian
Thank you for the fast answer.
That's a good start. I am new to COM programming. But it's time to learn!
A few more code snippets would be appriciated :rolleyes:
Regards
A few more code snippets would be appriciated ;)
@Hackbart
I don't think I need any more help for now. :D
Your Code snippet works great!
You are quite right, it's all there in the COM interface. It's actually quite easy to use even for a COM-newbie. :)
Thank you for leading me in that direction
