ouioui01 Posted August 20, 2007 Posted August 20, 2007 (edited) Hi, Well, first sorry for my english! I have a dual boot XP Pro SP2 / Vista x64. I'm using DVBViewer Pro 3.8.0.0 with TT S2-3200 card (latest BDA driver for the two OS) In XP: i have no problem (i can watch sat tv...) With Vista: i install DVBViewer Pro 3.8.0.0. But when i try to scan channels, the signal is strong, but the soft don't lock channels... Then i copy files channels (.dat + .xml) from XP to Vista dvb folder...start DVBViewer...i saw the last channel (FTA) with a non nulll signal (70 %) but no picture.... I changed filters without success Please, need help ! Thx. My config: Asus P5W HD Deluxe, DualCore Duo E6700 , Nvidia Geforce 7600GT (latest drivers from Nvidia) , 4Go RAM TT S2-3200 card, DVBViewer Pro 3.8.0.0 2LNB : 13°E + 19.2°E Cyberlink PowerDVD 7.3 --> Nvidia codecs --- support: support.zip Edited August 20, 2007 by ouioui01 Quote
Tjod Posted August 20, 2007 Posted August 20, 2007 Pleas post your support.zip i think there is no Video Decoder on your Vista. Quote
ouioui01 Posted August 20, 2007 Author Posted August 20, 2007 I format disk and install again Vista X64... I install DVBV again, and i have the same problem... You can find a new support file (video decoder is present) any ideas are welcome! thx! support.zip Quote
Benarty Posted August 23, 2007 Posted August 23, 2007 I format disk and install again Vista X64... I install DVBV again, and i have the same problem... You can find a new support file (video decoder is present) any ideas are welcome! thx! Vista32 okay but Vista64 is still a problem where hardware manufacturers have still driver problems. Vista64 can only work with 64 bit drivers and a driver may not contain some bugs cause Vista will try to find out buggy drivers and if one is found, driver removed from the system. Quote
ouioui01 Posted August 25, 2007 Author Posted August 25, 2007 Hello, Has someone a same configuration as me, there? Does he succeed ? thanks a lot! Cheers. Quote
ouioui01 Posted August 30, 2007 Author Posted August 30, 2007 Hi, Resolved by this way....but still don't understand hardware conflict (graphic card / TT s2-3200) 1- change port pci device -> still didn't work 2- plugin an usb device (webcam) 3- try again (the last one i thought)...and then it works ! Cheers! Quote
