DVBServer & 2xDVB Cards
mirc0n
How you are supposed to use two dvb cards from DVBServer with one DVBViewer client?
It seems that DVBServer supports multiple cards but DVBViewer has only one Unicast Network Device. Should it have two? ;)
I opened hardware.xml and made copy of Unicast Network Device, so now I have two.
It seems to work, but is it really this way you should use it?
- mirc0n
Edited by mirc0n
the other way is to edit usermode.ini and set unicastdevices to 2, and do a hardware scan... ;)
Maybe you should do that, because with a new hardware scan, you'll lose your second network device.
